TwinTurbo.NET: Nissan 300ZX forum - Re: Bad oil leak at the oil pump
brian913
on March 17, 2014 at 3:26 PM
posted by EmilZ
on March 17, 2014 at 09:44 AM
As I remember there is a part of the oil pump that goes around the crankshaft that has flats that drive the pump and there are pins that locate the pump on the block. It may be unlikely that this would work. Maybe someone has done it though.
EmilZ
09:44:36 03/17/14
Re: Bad oil leak at the oil pump -
brian913
15:26:14 03/17/14
The gasket behind your oilpump probably looks...
kickerzx
15:55:36 03/17/14
Damn photobucket wont work...
kickerzx
15:57:07 03/17/14
I just emailed you the pic Emil. (n/m)
kickerzx
16:01:30 03/17/14
Re: I just emailed you the pic Emil.
EmilZ
23:09:55 03/17/14
Have you verified its not a cam gear seal or gear itself? (n/m)
Woody75 (Denver)
13:18:43 03/19/14
